Handheld XRF Metal Analyzer provide highly specific material chemistry to rapidly and accurately identify alloy grades and pure metals. Get alloy chemistry and grade ID in seconds, from simple sorting to challenging grade separations, from incoming material inspection to end-product verification.
Configured with a standard package of 25+ elements, the metal analyzer generates alloy chemistry and grade ID in seconds. From simple sorting to challenging grade separations, the metal analyzer provides highly specific material chemistry to rapidly and accurately identify pure metals and alloy grades.
When you need a reliable analysis tool to provide fast and accurate Positive Material Identification (PMI), turn to the DELTA. From turnings, shavings, rods, and wires to small parts and components, to more sizeable material or structures, the DELTA provides anywhere, anytime testing with faster and more accurate results than ever before. There are also many types of metal analyzers like slag analyzer, spark optical emission spectrometer, precious metal analyzer and karate tester.
Among all the metal analyzers, versatile gold analyzer is the most widely used one. The GoldXpert is a stylish countertop analyzer fit for the consumer showroom environment. Designed to be compact and lightweight, weighing only 22 lbs (10kg), the GoldXpert can be transported easily to wherever testing is needed. The GoldXpert gives accurate chemistry and karat results within seconds.
Nondestructive Precious Metals Assay and Karat ID
XRF is a widely used, proven, and accepted method of chemistry analysis and determination of purity and fineness of precious metals. XRF analysis is a multielemental testing alternative that is quicker and less expensive than fire assay and chemical tests. XRF provides on-the-spot analysis of your silver, platinum, and PGM metals and impurities, making it an easy way to boost customer confidence and ensure dealer reliability.
Given the current high value of gold, quantifying its fineness and purity is more critical than ever, whether you buy gold, sell or produce jewelry, fabricate metal, or recycle scrap metal, you need a fast, highly accurate method to determine karatage (gold content) for quality control and pricing. The Innov-X GoldXpert XRF analyzer is an easy-to?use, cost-effective method to obtain alloy chemistry and karat classification with one nondestructive and nonintrusive test. Additionally, an exclusive GoldXpert software feature helps identify gold-plated objects and sends an alert to the screen.
The High Performance XRF Gold Analyzer is designed to be compact, taking up minimal countertop space. It is an attractive design suitable for the showroom floor and an easy-to-use analyzer providing karat and compositional analysis results with one push of a button. It can get accurate chemistry and karat results within seconds with innovative feature to help identify gold-plated objects.
Besides, some other machines may be used such as plating thickness analyzer and Coating Thickness Analyzer to analyse gold.
skyray-instruments.net
Użytkownicy przeglądający to forum: Obecnie na forum nie ma żadnego zarejestrowanego użytkownika i 22 gości
